Cylinder # 3 in my '92 has zero comp. I lined up the marks at 3 and 6 (correct?), put air to the spark plug hole with a glove on the exhaust and PCV valve out. PCV checks for bad rings, glove for exhaust valve and glove over TB for intake valve. Exhaust glove inflated. Did I do it right? Started it with exhaust glove still on for giggles. http://www.youtube.com/watch?v=fbemE08N5uM
Cylinder leak test
You need to make sure the cam is on the compression stroke for cylinder #3.Brian
No, the cam turns twice as often as the crank, so 6 & 9.1963 Fairlane - future NSS drag car
If you're not sure just pull the VC off and you will know for sure when both valves are closed by the lobes on the cams. But its been my experience lately that #3 likes burning up valves. Last two motors I've rebuilt have had burnt exh valves on #3.No festiva for me ATM...
LOL!! You're right. Not sure what I was thinking.Originally posted by georgeb View PostIt only turns half as fast.1963 Fairlane - future NSS drag car
Wulfgarthegreat had a burnt number three, and so did mine two weeks ago, prompting my B6 swap. Freaking number three!Originally posted by htchbck View PostIf you're not sure just pull the VC off and you will know for sure when both valves are closed by the lobes on the cams. But its been my experience lately that #3 likes burning up valves. Last two motors I've rebuilt have had burnt exh valves on #3.
Beamed to you from an insane asylum in orbit around Saturn via Tapatalk.Contact me for information about Festiva Madness!
