I have read the post on testing the TPS and have a couple of questions.
First, on my 91, the top wire is a constant 5 volts, the middle is the ground (black, and confirmed ground by a continuity test to the ground on the battery) and the bottom reads nothing, or 12 volts, depending on throttle position. This is different than most of the things I have read, where the top wire was listed as the ground.
There is no varible voltage reading with movement- it is all or nothing. Top wire goes from 5 to zero as you approach WOT- as expected. The bottom wire goes from zero to 11.67 with a couple of degrees of movement off idle, then stays there for the rest of the range of motion. Nothing variable.
When I checked for resistance, it was all or nothing again. I went from zero resistance to no current flow within a couple of degrees motion off idle, and nothing in between.
I'm guessing that this, combined with the inability to idle without a significant amount of throttle added, means that after 21 years and 152000 miles my TPS has sensed its last throttle position.
Am I missing anything here?
