Need help brainstorming.
Did the B6 swap, and have been having a ton of issues getting the intake stuff I bought to hold a seal.
I finally had it, or so I thought, and was reaching for the hood prop to shut the hood, and go for a test drive, when BLAM. The engine just shut off. Turned out to be no spark.
Quickly, I tried a different coil, and dizzy. Checked the wires to the dizzy, all good. Coil and dizzy also worked in a different car.
So, I plan on swapping out the ECU, and ignition switch. What else might it be?
