Have a loud shreeking noise coming from front end of engine at idle. Took off v belt from alt and wpump and noise is still there. Anyone ever have an oil pump go bad?
Strange noise
May be your timing belt tensioner pulley. Those bearings make some noise when toasted.
Sent from the bathroom via crapatalk.91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
92 L 5sp "Red" RIP
95 Grand Prix SE DD
Wife's Stuff:
89 L 5sp "Carby Car"
97 Aspire auto "Pink Panther" Build Thread
Spring 2013 IndyStiva:
http://www.fordfestiva.com/forums/sh...eet-April-20th
You might be able to locate the noise using a home-made stethoscope. I use a 3' long piece of garden hose. A stick of wood pressed between the engine and the side of the head could also work.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by denguy View PostWhere is the washer? I am away from my car stuff.
