Someone else mentioned in the thread, the camshaft position sensor is in the distributor. The coil wouldn't be firing if the CPS wasn't sending a signal to the computer so that leads me to wonder if the injectors are getting their +12v.
quick question about what sensor controls injector firing
I always assumed the spark was delivered completely mechanically since the disty is driven off the cam, timing it, or does the ignition module have to see a signal to know when to allow the coil to fire?93 Probe GT-Twincharged-11.992@115mph 10lbs
-11.940@111.66mph 14lbs(Slipping clutch)
123.7mph highest trap
95 Probe GT-RWD-4.8LS-Turbo in process-10.240@135.3mph, Turboed, 3300 race weight
But yeah ill check for 12v at the injectors and use the test light93 Probe GT-Twincharged-11.992@115mph 10lbs
Do you know what years that is for? I've looked on my motor(89), and on the motor out of the 90 that I parted, and neither have a Crankshaft position sensor.93 Probe GT-Twincharged-11.992@115mph 10lbs
^^That would be a CAM positioning sensor, not the Crank sensor
Ok thanks guys. After checking the injectors that's where I'll start looking.93 Probe GT-Twincharged-11.992@115mph 10lbs
You can have the plugs firing without the injectors firing. I had that issue on my 93.
I had spark but the injectors were not firing. I changed the disty and it fired.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
RI have already replaced the disty. and now i have checked the injectors and i do not have 12v to them so i think i will try to find the wires at the ecu and make sure its working, besides that i dont think it would be anything else.93 Probe GT-Twincharged-11.992@115mph 10lbs
I was about to offer to send you some festiva wiring diagrams to try and help out... but i realized yours is an 89' which would be different then the diagrams i have
You only need a noid light to see the ecm side flash while it is running.
A led test light works the same.
A standard test light will show power from the main relay
It will show bright-dim while cranking with a good battery.
A weak cranking system will show bright-dim every where
because the starter bucks each cylinder. Don't confuse a week
battery/starter/connections for the injector being fired by the ecm.
That is why a noid light is better but not necessary.Reflex paint by Langeman...Lifted...Tow Rig
Well while i was messing with it i put a test light in an injector connector and it never lit up93 Probe GT-Twincharged-11.992@115mph 10lbs
