I'm gonna change the control arms on my Festiva (the red one) to keep it on the road for now, but since I'm changing knuckles and putting new struts and springs on it, I want to freshen everything up and get whatever parts will prepare the car for further mods.
That said, has anyone used Rio control arms, and do they work for us? Are they too long, too short, offset, etc...
And what about the EGT or Rio rear beam? Is it wider than the stock/aspire beam? I want a wider wheel base without using high offsets.
Is there enough room to use an offset bearing plate with a spherical joint for the upper strut mount to make up for the offset from using Aspire LCA's?
