Okay. I know there are a LOT of topics on this, but I've searched several hours over the past few days, and can't find any solid info on REAR-ONLY Aspire swap. I don't have the funds for a complete swap.
I've been burning through rear bearings within 4-7k from new. A friend (gauge_half_inch) helped me replace the last bearing fail (along with teaching me how to replace them
), and looked over my spindles. He said it'd be best to replace them, and you can't buy them new. Today I looked at the parts car ones, and they look pretty bad.. All I've found for used are $40-50+ each. Minimum of $50 (both) at Pull/Pick-a-Part.
So brings my questions:
If I buy the whole brake assembly from as Aspire (I found a full rear beam + brakes for $125 removed locally, is this price decent?), will it be too strong for my front brakes/cause spinning in snow? I already have some 14 inch Tracer wheels with 4x100 pattern (will need new tires), while my fronts will stay 13 inch (155/80/13's most likely, unless there is a suggestion on better fronts with this set-up) for the time-being.
I know the rear tire stance will be wider, and wondering if that'll affect anything.
Along with this, I will be putting front Festiva springs (parts car) onto the rear, with the Aspire beam, as I bottom out pretty easy back there without passengers.
By searching Aspire swap threads, it seems like something I could do with the tools I have, though I'll likely need a breaker bar (I have no torches or experience with one! :eeeeeek
Sorry to start another Aspire thread, but I'm hoping someone who's done this can chime in.
Thank you all!
~Joe
EDIT: I hope this is the right forum. If not, I kindly request that you would please move it to the correct area.
), and looked over my spindles. He said it'd be best to replace them, and you can't buy them new. Today I looked at the parts car ones, and they look pretty bad.. All I've found for used are $40-50+ each. Minimum of $50 (both) at Pull/Pick-a-Part.So brings my questions:
.Sorry to start another Aspire thread, but I'm hoping someone who's done this can chime in.
Thank you all!
~Joe
