Hi all, my festy is having afew issues that i think could be related to an air leak but i'm not sure where to look.
problem #1 the brake pedal usually moves too far down while stopping. it feels similar to the symptoms of a bad brake master cylinder but different because it still stops ok as long as you apply enough pressure to the brake pedal. It also works better if you pump the brakes once before stopping. This leads me to believe that there could be a leak in the air system causing the brake booster to not work properly.
problem #2 the car has an irregular idle / idle bounce that generally occurs in the 600 to 800 rpm range. also leading me to believe that there's a leak in the air system.
where should i look if this is indeed an air leak ? Is there supposed to be a check valve in the hose that connects the intake manifold to the brake booster ? because mine doesn't have one and i know most cars do.
