so I installed a radio from a different car I had laying around and had it all hooked up fine and completely installed and then all the sudden the radio would only work when the key was in the accessory position, when it was on, or the car was running it wouldn't turn on at all..... I'm measuring 18v at the power wires to the radio so I got enough volts, maybe i'm drawing too much amps or something? One thing I did notice right before I got out is the radio shut off when the auto seat belts kicked on when opening the door....any suggestions for when I go back out to mess with it?
thanks in advance for any help!!
right now taking a break and getting some grub.
