Checking out Laurels 89 auto with a no start issue. Fuel to the rail, noid light shows injectors firing, bright white spark, so I am looking at the timing. It has two marks a few degrees apart. When I line the cam to 12 and 3, one lines up on a tab, but not on the "T" on the timing belt cover. If this correct? I haven't lined them like this in a long time!
Call the authorities, Scitzz has escaped the Insane Asylum again!
