So I have some wiring issues I think. The turn signals don't work up front. When the headlight are on bright the defrost and turn signal lamps in the dash are on and dim. When the flashers are turn on with or without the headlights on the tach, bright signal and defrost lamps flash and bounce. And ideas where to start?
Hazard/Gauge issues
Grounds-Greg
Redneck Engineer
FOTY - '09
also look for the main dash harness ground near the ECU.Trees aren't kind to me...
Good call. They are easy to miss.Originally posted by whatle View Postany missing grounds after the wire tuck and battery relocation?
What about the groundingblock behind where the stock vaf is? It gets over looked. Another culprit could be the headlight switch. I've seen them do some funny things.
Time to start wiggle testin-Greg
Redneck Engineer
FOTY - '09
