carb to efi swap fuel pump
  • carb to efi swap fuel pump
    has anyone used an inline fuel pump vs. swapping out the tank? if so what pump did you use? where did you mount it? and what pressure is it rated for?
    thanks
    Yup been done many times. Mounted under the hood or in the fender. Walbro 255 Lph. Rated for efi pressures 40psi or higher.
    -Greg
    Redneck Engineer
    FOTY - '09
