I had one go out on me recently. I had another 93 here at the time that was running to test it out, and was able to isolate that it was the problem. I ALSO have a 93 here that isn't running, that I grabbed an ICM off of to get my car going. Cleaned the mounting surface really well, used thermal paste of the type that you use for mounting CPU's, and installed it. Ran fine.
All night I have been doing a bunch of work on my car. New intake gaskets, and conduit for all the wiring. Tightened the sometimes squealing alternator belt. Odds and ends, trying to polish off this B6 swap in time for Madness. Start her right up, and letting her run and warm up. Start putting things away, and just like a few weeks ago, she cuts off in an instant, Deja Vu, right?
Pull a plug, check for spark, nada. Swap in a known good coil. Nada. I am thinking ICM again, and Oreilly has one in stock.
What I am trying to figure out, tired as heck, and ready for bed, is two things. One, is there another test to be SURE it is the ICM, and is there something that could be causing them to go, or was it bad luck, both 20 year old parts just went? The first one to go had NO paste left on it, and when I pulled the other, it didn't appear to have any either. I have no idea the history of that car, or how long it has been since it ran....
I am thinking that should be the same stuff.
