I'm having a bad issue with my driver's side windshield wiper.
When the wipers are running, the driver's side one will go to far to the edge of the window and will eventually wrap around the A pillar and get stuck.
When I release the wiper, it only goes halfway down the windshield.
If I push the wiper all the way down manually, it will work normally for a minute or so then gradually work it's way farther out again.
The base where the arm mounts is very loose and the cowl metal appears to be cracked.
Would the bad mount cause this issue? And if so, how can it be fixed?
