Where can I find the rack bellows/boots for a 93 festy? Everything I find is for power steering.
manual steering rack bellows
I believe they are supposed to be the same/same. Someone correct me if I'm wrong.
Same goes for exhaust down pipes these days; only thing available is for automatics. Once you see one and realize it's bigger diameter pipe (the only difference) you can understand why they only offer that type, even though they were standard equipment only on automatics originally.
I would think P/S racks and manual racks use the same boots. I have scavenged the inner tie rod boots off an auto Aspire for use on a manual Festy, by the way.
