Please forgive my poor cinematography skills.
It was suggested perhaps my smoke problem is not ring related, but rather a PCV issue. The PO could not give me any information on this problem, but given the amount of sludge this didn't happen yesterday.
I replaced the PCV valve and hose. Also, I added a catch can. The oil on the valve cover is coming from the breather hose.
Just before the video was shot, I:
-squirted a little ATF into each spark plug hole
-took off the PCV hose and sprayed carb cleaner into the intake manifold, followed by scraping with a piece of wire; cleaned and blew out the PCV
-sprayed down the EGR pipes and scraped them as well.
Of course when my engine is ingesting considerable amounts of carbon sludge, it's expected I might have a clogged EGR pipe. EGR valve operates as it should.
I don't generally have smoke from the exhaust, but as you could see in the video, I do usually see smoke coming from the exhaust flange.
I know I didn't exactly eliminate any variables by doing all these things at once, but the general issue still remains:
There is an abundance of gasses and pressure in my poor precious B3.
Thanks for taking the time to read and watch. Hope it was enjoyable
Piggyback question: Gas gauge- It reads accurate, but goes to empty sometimes. No change after replacing the sender. Is this more likely a bad ground than the reader wire? I can't seem to find the ground screw to the chassis. Have I not explored far enough?
