I think I may have been mis-informed. There is nothing wrong that I know of with my front bearings, however, my rotors are pretty warn out. I have new rotors. Do I have to replace the bearings/have them pressed to replace the rotors?
New rotors without bearings?
Http://www.Youtube.com/TheresGabe
1991 Festiva L Red: Daily Driver
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1991 Festiva L Red B6T: R.I.P.
1989 Festiva L White: R.I.P.
1995 Aspire 2-door White: R.I.P.
1995 Aspire 4-door Red: R.I.P.Tags: None
If its Festiva then the hub has to disassembled to replace the rotors.
If its Aspire then the rotor can be replaced without disassembling the hub.
Sent from somewhere west of here!Ian
So in order to do the rotors, I have to take the entire knuckle off anyway, so I might as well replace the rotors then. And I might as well wait to do all of this, when I do my new front shocks?
Last edited by WmWatt; 10-12-2012, 10:21 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Kind of like a clutch throw out bearing....if you see it change it!1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
There was an option 1/2 decade ago (at NAPA in Canada) to buy Festy rotors alone or with so-called matched hubs with already pressed-in bearing races. The price difference was substantial so I never went for it at the time. In hindsight I can now see why it was offered. When else is a Festy front hub removed from the car just for the helluvit.
