Dist. cap gasket & spacer?
  • Dist. cap gasket & spacer?
    Does anyone know where I can find the thin gasket that goes between the distributor cap and the spacer? Have looked everywhere I know of so I need a wider knowlege base. Any help would be much appreiated. [slotmachine0143@att.net] -dragcar-
    Does Rockauto carry it? I'm not quite sure what the proper name for the part is, but they probably have it if it's a common item to replace. If it isn't, your best bet is probably finding another one in a junkyard!
    1988 Chevy Sprint Turbo 997cc
      Re: Dist. cap gasket & spacer?
      They're supposed to come with a new dizzy cap. Never seen one packaged individually. I used a light spot of rtv.
        Wasn't aware of any "spacer". I don't think mine even have a gasket.
          No, they don't come with the dist. cap. Thanks anyway. -dragcar-
            Yeah I just put on a new dist cap and mine didn't have one either.
            1993 Festiva GL The Besty Festy
              I've seen one made from a sheet of paper gasket material. Trace and cut. Cutting the circle out of the inside can be a bit tricky. Patience and an exacto knife will get the job done.
              Sent from the bathroom via crapatalk.
              91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
              92 L 5sp "Red" RIP
              95 Grand Prix SE DD
              Wife's Stuff:
              89 L 5sp "Carby Car"
              97 Aspire auto "Pink Panther"
              Build Thread
              Spring 2013 IndyStiva:
              http://www.fordfestiva.com/forums/sh...eet-April-20th
                ebay fel-pro 35608 distributor gasket part 35608
