This has been bugging me for a while and I just want to get some experienced opinions...
Here's some background: Bought my Festy on August 1st of last year. When I went to replace the timing belt, the repair manual said to remove the spark plugs for some reason....I have no idea why. Well, I attempted to and two of them broke right off with the threads still in the cylinder head.
So, my dad and I removed the whole cylinder head and sent it to a machine shop where it soaked in penetrating oil for a couple of weeks before they finally got the spark plug stubs to come loose(came back squeeky clean
As we were putting it back on, we accidentally moved the head gasket a little from where I had it positioned. However, we made an untested decision that just getting the head bolts in would re-align it (Is this correct?). We should have double checked before making that assumption
Since performing that service, it seems that the hydraulic lifters have made more noise than before when I bought the car. I have put about 7,000 miles on it since without engine issues, but would this be a symptom of not getting that gasket on correctly (maybe partially blocking off an oil hole)?
THanks!
THanks!
