My 91 has a noisy lifter after it sits for a few days. It goes away after it warms up. I am going to be taking off the valve cover to replace it's leaking gasket. Is there anything I can do in there to silence the lifter short of taking the valve train apart? I don't know which lifter it is at this point.
Noisey lifter
have had several festiva with noisey valve train. the lifters have extreamly small passages and the slightest dirt cloggs them.
try a fresh oil change with a bunch of seafoam, let it idle for 20 minutes then change oil and filter . if that doesnt work replace the lifters. since they are in the rocker arm you dont have to pull the engine apart to get to them. You can get a set on ebay for 40-50 bucksLast edited by NovaSS; 10-31-2012, 03:53 PM.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
Seafoam is like $6 and has more benefits than just fixing a noisy lifter... I'm a big proponent of letting the smoke fly with some seafoam!Originally posted by bhearts View Postscrew the seafoam. use diesel fuel. i put in 1-2 quarts in my crankcase before i oil change and just let it idle for a while. then drain. deisel is great and removing sludge and gunk.
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1989 Festiva L White: R.I.P.
