I'm not sure what's not operating, but my blower motor isn't pumping out any air anymore. I don't hear it kick on. I know it has worked in the past, but now all of a sudden it's not. I'm not sure if it's the blower motor or if it's the switch for it on the heater controls. It's starting to get cold and I need this thing to work...if for nothing else to help defrost the windshield.
Is there anything I can do to diagnosis the problem? Or do I just need to purchase a blower motor...swap it out and see if it works...if it doesn't then do the heater controls? I took all the heater controls out today to see if there was something not hooked up right. Everything seemed fine. My lights for the heater controls have been wonky lately...sometimes they work and sometimes they don't...though I have tested and whether they are off or on I still don't get any movement from the blower motor.
Pretty cheap and easy fix IF that is what is wrong. If the other tests show nothing wrong, pull the fan, three bolts, and wire it up to the battery, or any other 12V DC current. If it doesn't run...BINGO! Kingfish already gave you most of this though, so I guess I am just rambling.
