My sister's car crapped out on her a couple months ago, its the '88LX that I swapped to an ATX out of a '90 model. It was very low on fluid, had a leak from one of the cooler hoses. It still had enough fluid for it to go into gear and pull, but its like its stuck in 2 or maybe even 3 all the time. When you put it in reverse or in park, it still tries to pull forward and just bogs the engine out. In any of the forward gears it does go forward, but feels like its in probably second all the time, never even tries to shift.
Any ideas that could be up with it? I could just put another one in, but I can get a master overhaul kit from NAPA with all the friction plates and clutch plates and all seals for ~$100. I like the idea of completely rebuilding it, I've done a couple of 700R4s in the past, and I don't imagine this would be much more difficult but I could be wrong? Anybody open one of these up before? I know Jim has. What do you think Jim, would this one be worth trying to rebuild?
