So today we are trying to find out what the issue is on my 1994 ford aspire with the EFI B3/5-speed manual. It'll idle rough, but stay running. When you hit the throttle it'll just idle down then die. After a while of starting it, it'll rev up, then die, continuously. When you drive it and go into nuetral, or just shift gear's, it'll die. It just doesn't want to stay running.
I have replaced the distributer, IAC, TPS, O2 sensor, tune up kit. I do however have the two coolant sensor's to replace; the one in the front of the motor and the one by the intake manifold. At the end of the exhaust it sound's like "puff, puff, puff" kind of like it's missing, but it's not.
I will try to get a video of it ASAP.
. As soon as I get back I'll put the vise grip's on the return line, if that doesn't work or improve I'll do a compression test. If all else fail's, there's a half off weekend at LKQ and I'll get get a fuel pump or just buy a new one. Thank's for the replies and keep you. All updated.
