I worry I'll start to seem like the boy who cried wolf too often: However, I've been thinking more about my Festiva's motor; wondering about giving that a full overhaul as I did four times to the '66 VW "square-back" sedan I had a dozen years from '82-'94.
I think with the Festiva I'd like a professional's touch; since though I did good work on the VW, there were enough snafus I don't want to ever experience those again.
I'm imagining with 180,000 miles and some blow-by; getting everything in the head renewed, the engine cylinder bores all redone with new rings and/or pistons and rods, all balanced, and the crankshaft turned with appropriate size new replacement bearings. Also all new seals all over the motor, with a new oil pump and whatever else is worth replacing while the motor is torn apart. This cost me about $600 for parts and machine work for the VW, including rebuilding both Solex carburetors; doing all the work myself: New or rebuilt rods, cylinders and pistons; case halves align-bored and everything else.
I simply can't justify the risks of an used motor; nor the work of having to be constantly fooling around under the hood, experimenting. Thus, I feel the need to become a control freak so to speak. The same way I had to approach the VW; which was by spending more, to avoid uncertainty. With mechanically competent friends with secure places to work on cars, also able-bodied I'm not; they could afford to use old parts or any other number of reliable expedients, for an expert.
I'm in a town where I don't know anyone, and at age sixty-one doubt I'm going to make too many new friends, particularly automotive geniuses. So, I'm trying to imagine starting to shop around to find a shop which would work with me; getting the Festiva's motor overhauled. And, while at that also replacing the clutch, pressure plate and throw-out bearing.
One recent experience was having a local shop replace the passenger side drive-shaft and control arm on the same side, which has the ball joint. They charged me $165 in labor and some transmission fluid; while the shop which had recently replaced the water pump, timing belt, timing belt tensioner, alternator, valve cover gasket and seals on the crank and cam shafts, quoted me a price for the same $165 job-labor only, of about $360. The place who did the work for $165 based their charge on $75/hour shop time; while I have no idea where the $360 quote came from? Making me think I could've done much better elsewhere; for the earlier work they'd done, too.
Thus, the idea of shopping around looking for an engine overhaul; as mentioned above, seems like something with the potential of excellent results? And, I'm a convinced B3 fan, folks; with their excellent fuel economy, my bottom line. If someone were to lay a B6 on me I might seriously consider using that instead; since probably there'd be good mileage too, with a little more torque and power nice in a pinch. Though since I already have the current motor, and do feel having that made fresh a good long term investment; staying B3 is my plan.
When I was overhauling the VW's motors; using the John Muir Idiot's Guide was far from my bible, with companion manuals of other brands far more useful in many respects. Though I did get a cohesive sense of what I was doing; I'm far from feeling with the Festiva shop manual and the companion Haynes one. Maybe I've simply not immersed myself enough; though the anti-technological Idiot's Guide, sure made for feeling I had a blue-print to follow. If also letting me know why so named.
The Nazis' perverse character certainly is well reflected in their stunningly successful consumer product; which is worth some serious contemplation, as to the effect on the generations of the sixties and seventies and eighties well after the second world war. I've read a good number of the available holocaust survivor books; within which I've always tried to balance my horror of all the participant's roles, probably as much as anything due to the fact of being forced to do much of my own mechanical work to be able to drive, in societies where that is rare of most people.
I never think of money as a fair exchange; while always surprised in automotive endeavors, how some appreciate my knowledge and efforts while others dislike that...of the commercial entities I end up dealing with. The places who like stupid people; like them to have lots of money! Which is sure a dim philosophy; in my opinion. Only since discovery of Paul Polansky's Gypsy survivor books and his other books about Gypsies during the second world war, my ancestry; have I started to run across books so horrifying and discouraging I've not been able to finish them. I don't believe the propaganda of the Nazis, though do believe such propaganda is designed to touch nerves which are sensitive. Understanding the monstrosity of such agendas; is a project worth working at, too few seem interested in? Worth some infrequent skin off my knuckles at least.
