Need help have 91 festiva all stock 260,000 miles it has no power all the sudden the motor loses all of its go feels like someone is holding it back can someone help me get it back on the road please I'm the northern VA quantico area
need help
check fuses and the power relay under hood by battery.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
need help
Stops power to fuel pump I know that.;
'92 Festiva L M/T
'93 Festiva GL A/T
Is it pushing oil from the valve cover into the plastic part of the intake when this happens ? Assuming it is still running, just no power, and not rough but losing
power evenly from all cylinders. Fuel filter, air box problems or air box connector
problems. Loose plastic between air box and throttle body..many things can cause
problems your best tools are your eyes and common sense.Reflex paint by Langeman...Lifted...Tow Rig
need help
Check fuseable links.;
'92 Festiva L M/T
'93 Festiva GL A/T
