Hi all, i've been having a brake issue for the last 6 months because i haven't been able to figure out whats causing it.
I thought it was the master cylinder, replaced that, didn't change anything. Thought it was the driver's side caliper, replaced that, didn't change anything.
When you hit the brakes, sometimes it has good pressure, sometimes it has almost zero pressure, and sometimes medium pressure. When the pedal sinks to the floor, and you press as hard as you can to stop, you can feel that the right side of the car is doing all the braking. Also when it sinks to the floor, you can feel the warped rotor on the left side wobble, but when the pedal has pressure, there is no rotor wobble felt at all and the car stops smooth & fine.
If i bleed the driver's side caliper, the brakes will be alot better for awhile ( pedal still sinks to the floor occasionally ) but then progressively starts to loose pressure more often.
The only thing i can figure is it's gotta be a problem with the line, but it doesn't leak any brake fluid, so i don't have any clue what it could be.
Are there any check valves in the front brake lines ?
I suck at brake problems...
