Aqua ran today after I put her back together after a new head gasket. Seemed to run fine at first. Oil light works, but did not come on. Dipstick only showed to bottom line, though I kept pouring in more oil. I put at least 4.25 qts in but still only get to the bottom line on the dipstick. (I put in most of the oil by pouring it over the valvetrain before installing the cam cover.)
First run: less than thirty seconds
Second run: about a minute, with coolant cap off, checking that (fine)
Third run: A few minutes, during which I turned on the heater full blast to help circulate coolant on the backside, but then the engine dropped revs, kept slowing down and it seemed "bad" so I shut her off.
I feel like I'm toasting my engine!!
Still only a bit of oil on the dipstick. No oil light. There is smoke off the exhaust manifold but I figured that would be oil and dirt and cleaners burning off.
But that engine slowing down on its own, when it was running fine for a couple minutes scares me!
Why no oil increase on dipstick? Could the oil be blocked from settling in the pan?
Ideas please?
Karl
Ideas please?
Karl
