I have a bad habit of taking things apart that I really shouldn't
I actually ripped out the connector block trying to remove it so 3 of the connections had to be resoldered.
I was pretty worried after putting things back together. The car wasn't running very well. I pulled the battery for a minute or two but still no luck. It was fluctuating high/low at idle and would get so low it would almost die (and did several times) especially after revving.
i tried re-adjusting the spring tension for the metering device and somehow it seemed to work because the car was now idleing well. It drops a little below normal idle after I rev it but that may be normal.
