FLYWHEEL ALERT
  • FLYWHEEL ALERT
    Bought a new flywheel on ebay for an 88 stick Festy. After installing it we started her up and got this loud scrapeing noise from the clutch area. Found out that the new flywheel was rubbing on the plate between the motor and the trans. Turns out the original flywheel is undercut a little in that area and the new one isn't, but soon will be.
    Thanks for the heads up
    Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
