Hello Everyone. I have an issue that iv'e never had happen in all 31 cars iv'e owned.
While doing some basic upkeep on the festiva today i decided to look into the air filter.
Note that i have a 91 and a fuel injected system.
When i pulled the intake box off.
I looked inside and saw oil sitting right there on the inlet.
:nightmare:
I pulled the Intake tube off and then saw this.
There was sooo much oil i had to investigate.
I pulled off just about every hose, cleaned them out and put them back in.
I checked the PCV valve and its functioning properly.
I should also note that i leak oil from just about every seal. Crank case, Valve Cover Gasket, basically theres oil everywhere. I don't seam to burn any tho, just leak it all out everywhere.
Does anyone have any idea why my system is pressurizing and forcing oil out everywhere?
I believe it could be bad rings as well. But im trying to rule that out. Fingers Crossed.
Thanks, Andrew
:nightmare:
Thanks, Andrew
