What temp does fan come on?
  • What temp does fan come on?
    At what temp does the festiva fan come on? (fuel injected 5 speed)
    i wonder also. i've never seen/heard mine come on so i figure it's not working. never had a problem w/ overheating though. mines same, 5 speed FI.
    92l efi 240K+ stock
      97 degree celcius, about 250 f I believe what my shop manual says
      Logan
        Re: What temp does fan come on?
        The cooling fan switch has a range of 196 - 201 F.
          my 93 the gauge goes up about 1/4 of the way and the fan comes on.
          my 1991 the fan stays on all of the time and the needle goes up about 1/2 and stays there.
            my 92 stays about 1/2, right below the little pic and doesn't move also. but i've never seen the fan on.
            92l efi 240K+ stock
              My fan doesn't come on unless I've been stuck in traffic idling for 10 minutes, then it is on for about a minute, off for a minute. The sensor was broken when I got my 93, I pulled about 10 from junkyard cars before I found two good ones.
              OX SMASH!!
                Those figures seem REALLY high- i was thinking that it should go on much lower. Is this to keep the engine warm for better fuel economy perhaps?
                I'm installing a manual switch on the dash for the fan, because my festiva is running too hot for my liking. Does anyone know what relay the fan uses?
                performance > cosmetics
