buzzer wont shut off
  • buzzer wont shut off
    okay so i went to work this morning everything working as it should. get off work tonight open the door and no dome light. i didnt think anything about it except when i started the car the door buzzer wouldnt shut off. i opened and slammed both doors, i messed with the little black buttons still wouldnt shut off. so i had to drive 20 miles home listening to the door buzzer. anyone got any ideas as to what is going on?
    93 L plus 5 speed, custom herculined paint job, custom billet grille
    Door buzzer? I have always thought the buzzer is based on seat belts...
    1990 Festiva L White: R.I.P.
    1988 Festiva L Silver: R.I.P.
    1989 Festiva L White: R.I.P.
      Just unplug the annoying thing! Go under the dash and feel around for it, it will change sounds when you move it. unplug it and make it go away!
      -Josh R
        Sounds like something might be up with the sensor. Unscrew it and make sure it stops making a connection when the button thing is pressed in.
        -Rafe-
        Things I have for sale.
        Random Festiva Parts
          well i already thought of that but i cant expain y my dome light no longer works. coincedence?
            hmmm. Blow a fuse or something? Check your bulb, but I don't see how a blown bulb would cause the buzzer to stay on..
            -Rafe-
              Really cool paint can do that, but its worth it!!!
              Looks like your paint is holding up well.
              If I remember right a blown fuse turns the buzzer on.
              Just joking about the paint causing it!
                paint is holding up great... it was dark and cold ill check fuses in the a.m. thanks movin
                  My car has never had a buzzer, and the dome light worked once for like 5 seconds, I must have the same problem as you!
                    There are wiring diagrams for the '93 in the "sticky" threads at the top of the forum home page.
                    Go to the top of this page and click on the back arrow or on "Repair Help Forum" to return to the
                    repair forum home page.
                    If you have a Haynes manual there are wirning diagrams at the back.
