OK, so on 1991L West replaced the ignition module in the distributor, we checked the fusible links, We have 12 volts at the coil, have 12 volts from the PCM to ignition module, Have ground to the ignition module...No continuity between ignition module and the coil, and there was none. Tried to bypass and still no spark! GRRRRR!!!!!
HAVE NO CLUE....NO SPARK! HELP!
