Ok so i went out side today to try and figure this one out.
Unpluged the wire to the fan switch in the t-stat looked ok pluged it back in didn't do anything the fan still on as soon as the key is turned to aux even. unplugged the fuse and the fan don't come on. so yeah put the fuse back un plugged and plugged the thing back in again and well it still don't work its always on... could this be a stuck T-stat because even after or what else could it be? 10 mins of idle with no fan the engine temp gauge still was rock bottom.
