Need a help with A/C crankshaft pulley
  • Need a help with A/C crankshaft pulley
    OK, I can't figure out how to install with 2 pulley set with A/C replace over one main pulley...
    I just found out my 1992 Festiva L without A/C have different pulley hole size with four little bolts while I got parts with two set pulley (one main for alt and water pump and second pulley one for A/C)
    Is there two different size crankshaft fitting? or what?
    Anyone can help out with that?
    Thanks.
    The pulleys for 88-92 are different than for a 93. You might have the wrong year.
    88L 328,000 winter daily driver
    93L 167,000 summer daily driver (AC)
    90LX 374,000 swap candidate
    88LX black- parts
    89LX burgundy-parts
    91L red-parts
    Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)
      Uhmm... probably my new engine was 1993 but does have different kind pulley for AC on 1993 engine?
      I wonder if 1993 and later aspire engine same size bigger round with four bolts AC pulley?
