I recently purchased a 88 festiva. The car had sat for approx. 5 years. Owner said it ran fine when he parked it. Installed battery and put gas in her and she fired up. Did some general maintenance fuel filter, plugs, oil change, replaced valve cover gasket(had leak), and replace brakes/master cylinder. The car idled fine and started easy. Drove to the store 2 miles and topped off fuel tank. Decided i would go for a Cruz and made it 11 miles before it started sputtering under a load (let of clutch) would idle fine but when in gear wanted to die.
Got home changed fuel filter. Same issue once car warmed up.
Changed plug wires, distributor cap & rotor, ignition coil, and rebuilt carb. Once again car Idled and ran fine for about 5 miles then started the same issue except now it won't even idle.
Any help or direction would be greatly appreciated.... Thanks in advance for any help
