Every time I've bought wires for a festiva, The coil wire has been just long enought to reach. Is there any other make or model which will give me a little longer coil wire?
Weird. Mine almost seems too long, it hangs down and rides beside the battery and almost on top of the transmission. I'm sure you could check out a set at McAutoparts for a Protege/Aspire/Escort/Miata etc...
Buy some bulk wire and make your own set of wires to the exact length you want. You can put on some fancy covers. You will require a bench vice, a cutting blade, and a hammer. Do all of your cars, including your neighbor's. That way, they won't complain about all the Festivas in your driveway.
