2004 Rio Suspension??
  • 2004 Rio Suspension??
    I have found a 2004 Kia Rio being parted out. Can I use the front suspension and rear spindles+brakes on my 93 Festy? Only have a few days till it is getting recycled, so I gotta jump if it is going to work.
    HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
    "CL4P-TP" - 93 Festiva L
    The front suspension has to have 2 bolts on top to fit the 2 holes in the Festiva fender, not the 3 bolt version.
      Phoenix (on this forum) has a very good recipe for front brakes from these cars (03-05 Rios). Not much else is usable. Rear end stuff is of no use at all and front end goodies are (I suspect) limited to calipers, knuckles and discs. Top hat is likely a 3 or 4 hole instead of what you want. But 10.5 inch vented and floating rotors certainly is something for any and all Festy owners to Aspire(?) to.
        Re: 2004 Rio Suspension??
        Thanks!... nice pun
          What Bert said , the brakes / knuckles /rotors ext tie rods , you can take , the rest its unsure (struts and other parts)
            How about interrior stuff? Guy wants me to buy the whole car minus engine.
              If you need any help with things let me know, I don't think you are to far away and i would be willing to make the drive
                That would be great!
                I will let you know how it goes. Made an offer, waiting on reply.
                Sent from my AT100 using Tapatalk 2
                  Getting the parts Sunday!
                  If everything looks useable I will start Monday.
                    Crap!!!!
                    Pnp cubed the aspire I was gonna get the rear off tomorrow!!!
                    Alternate rear parts to get the same bolt pattern?
                      Just the Aspire... and why the hell did they cube it when you were getting parts from it? Didn't they know you were coming?
                        As if they care....lol
