I am trying to bring a car back to life after setting for a year or more. Odometer shows 201000 miles. To begin I changed what appeared to be the original fuel filter. There was no fuel in the tank so I put in
about 1/4 tank by the guage. Checked plugs etc. and then attempted to start. Nothing but engine cranked without problem. Next after trying several starts I loosened the gas cap and got a nice hiss which indicated to me the fuel pump is working. Tried to start with fuel cap loosened. No start. Next, I shot carb cleaner into the pcv vacuum port connect on the intake manifold. Tried to start and got a sputter. More carb cleaner and got the engine to run for a second or two. Problem then is definately fuel. Any suggestions as how to proceed? Has anyone put a tee into the fuel system to check pressure? If so, where and can it be left there for the future? Anyway to test injectors? I am hampered on funds so I can't afford to guess and throw parts at it like I used to do. Seems it always the last part you try. Murphy's Law!
Thanks for any help you can provide.
Also any body find a place that sells carpets for the floor?
