I have b6T that I am running on 91 @ 15 psi with reich racing ecu. I have been running this for quite a while now. It had a full exhaust system until the other day. I took it off to make my own. Now I spool instantly and if I do full throttle runs it will pop and backfire and bog out. Any ideas what's going on?
B6T blowing out spark?
Re: B6T blowing out spark?
Is it still running 15 psi or is it spiking? A vj14 with open exhaust will spike out of control...there's not enough flow through the wastegate to control boost.
Otherwise...regap your plugs. .030" max91GL BP/F3A with boost
^^this FTWOriginally posted by bhazard View PostIs it still running 15 psi or is it spiking? A vj14 with open exhaust will spike out of control...there's not enough flow through the wastegate to control boost.
when I first got my KL turbo'd I couldn't go WOT passed 4k rpm because the spark plug gap was too big, re-gapped to .030" and problem solved
Original plugs and wires! Haven't even pulled a plug yet. This b6t is untouched other than the religiously document oil changes. I have zero spike. Full throttle in 4th or 5th is 15 and it holds is smooth. It used to be 14 in 1st and 15 in second and third. I had spikes but then played with the turboxs hpbc and now it's perfect. Since spark is blowing out I can't get full boost in the first 3 gears unless I ease into it. 100k on original plugs is that too much to ask?Last edited by Ford Fester; 01-18-2013, 10:25 AM.Ford Fester
Run NGK v-power, and tighten the plug gap a few thou from the tight spec in the book. These engines are picky when it comes to plugs. You may want to go 1 heat range colder if you plan on long full boost pulls.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
