1993 festiva-
Lights don't work. Daytime corner lights never worked and I don't really care about them, but main lamps are suddenly not working.
The switch on the steering column trips the headlamp relay- but lamps don't work. Wires are ok from relay to headlamps.
All fuses and fusible links are OK.
The bright light indicator does not show up in dashboard when switch on steering column is set to brights...
What else can I check? I just installed a manual switch for the radiator fan, but it worked with that for awhile. Any ideas?
