So, it's a case of the good, the bad, and the ugly.
The good:
The bad:
The ugly:
To solve the bad and ugly bolt holes, I'm going to need to pick up a few things tomorrow before the valve cover with a new gasket can go back on obviously. One of them is going to be a tap so that I can have proper coarse thread M6x45mm bolts going through. Currently, the good and the bad both thread bolts with no problem even though the bad is slightly damaged as you can tell when I was removing the old remains. I should re-thread it anyway. The ugly needs some sort of extractor kit to remove what's left of the old bolt stud from my head and then to be re-tapped accordingly. Then I'll be 11/11 instead of 9/11 holes and oil leak-free!
So the question is this: what exactly is the name of the first and second tool specification I need to pick up at the hardware store tomorrow? I know the first is a tap, but not the correct name in order to properly thread the bolts into the head. Again, they're M6x45mm and I think the thread pitch is 1.0mm. The second is an easy-out or a bolt-out or a screw extractor or something. Thanks all!
The good:
The bad:
The ugly:
