Stranded... What fun...
    Re: Stranded... What fun...
    Originally posted by crazyrog17 View Post
    Fusible links are under the hood on the driver's side shock tower. They split the power from the battery into three circuits, one of which is engine control.
    Those fusible links can be replaced with PAL cartridge fuses, 30a, 40a, 30a left to right respectively. They're much more effective than a bridge wire fuse.
      Originally posted by sickfleming View Post
      That actually popped in my head too. I haven't changed one before but I have heard some stories about their failures on this forum, among other sensors. But I'm a little slow when it comes to which symptoms lead to which sensors, particularly on these pre-1996 cars which aren't scan tool applicable.
      How do you check for a bad cam position sensor exactly?
      I just pull a spark plug & check for spark. Doing this tells you your coil,ignition,cps & spark plug are good.
      If these check out you dont have fuel. If you dont have fuel it be a few differnt fuse's or your VAF connection (wiggle the VAF plug). Check your fuseable link & fuses.
      FYI, when driving 20+ year old vehicles I carry an emergency tool kit. Flashlight,Test light,Multimeter,fuse's/fuseable links,spare bulbs and a couple basic tools (BFH also but not recommended). You can buy all this stuff for a bowl of rice @ Harbor Freight. And will fit in a canvas "Ammo Bag" under your seat.It has saved me a tow truck coule times over the years
        Sage advice! We are no longer of the vehicle owner mentality that can afford to stand beside a dead car and merely look helpless and stupid. I admire anyone that DDs a 20 year old car.
          These vehicles WILL teach you independence, if you have the desire (or necessity) to repair them. My younger sister is learning about this, and while some of the issues have been repaired professionally, she has learned to diagnose and repair before becoming overly concerned about her situation. I personally dread the day I can no longer work on my own vehicle.
            Thank You Bert,it can be trying at times.But the end result is usually well worth it.
            Exactly! This is what I've been trying to convey to my College kids (Son & Daughter). They've gotten a lot better.In the past they would get frustrated & want to sell his they're cars. They've gotten wiser & more patient about break downs.
              If a festiva EVER won't start unexpectedly, or dies unexpectedly, and it still has fusible links, CHECK THE FUSIBLE LINKS!
              Http://www.Youtube.com/TheresGabe
              1991 Festiva L Red: Daily Driver
              1990 Festiva L White: R.I.P.
              1988 Festiva L Silver: R.I.P.
              1991 Festiva L Red B6T: R.I.P.
              1989 Festiva L White: R.I.P.
              1995 Aspire 2-door White: R.I.P.
              1995 Aspire 4-door Red: R.I.P.
                I DD a 25 year old car :lol:
                Buck.
                -1993 Ford Festiva GL, ~200k, B6, Aspire rear, Rio front, 5-speed. '87 Prelude alloys. Happy to be back on the route!!!
                -1999 Toyota Sienna XLE, 346,000
                -1996 Chevrolet K1500 Z71, 350 V8, 198k, hauler
                  read the sticky a few lines above;
                  With a squeak coming from the trans end of the engine, I would pull out the distributor and make it turns freely, and that the drive tang hasn't bent or sheared. I had one act exactly like yours. The distributor bushings tried to sieze the shaft, bent the drive tang. It still had spark, but now at the wrong time. Cranked fast like a broken belt, too.
                  Jim DeAngelis
                  kittens give Morbo gas!!
                  • #24
                    I definitely agree. I always carry my tool bag, sledgehammer, pry bar, jack and Jack stands with me, plus lots of lube. I hate those scissor Jack death sentences.
                    - 1996 Ford Ranger 2.3L 141,240 mi (Traded...wish I hadn't)
                    - 1996 Ford Probe SE 2.0L Auto 126,000 mi
                    - 1988 Festiva "Hermes" 1.3L Carb. 4-spd. 167,000 mi (Found a new home)
                    - 1994 Escort GT, 5-spd. with Pacesetter header, and exhaust kit 101,412mi (RIP...T-boned by ditzy driver)
                    - 2002 Hyundai Accent 1.5L Auto 164,000mi (Wow...so this is air conditioning...)
                    - 1991 Festiva, 1.3L 5-spd. 75,802 miles. Goes by "Trixie"
                    • #25
                      Is the drive tang on the cam? If it's sheared, I hope that doesn't mean cam replacement or anything...
                      • #26
                        Its on the DIZZY. Maybe its the just the pin that sheared. I figured you had this thing running ,what have you determined so far?
                        • #27
                          Well we just finally got my car back from the bank where it was parked via tow truck, which took a good while along with errands I had to run, so I really didn't get much time to give the car the full colonoscopy lol. I did try to turn the engine over, in regards to the ignition control module a couple of you mentioned, but well... Same as before. No start.
                          I'm going to take a look tomorrow...or well, today after I get some sleep. So I'm going to check my fusible links and take a look at my distributor, along with looking at my timing belt and checking my fuel pump and spark. Just out of curiosity, is there any way to check for fuel pressure without a gauge?
                          • #28
                            During the non salt months (over the past 8 years) I DD an 86 F150 that I've owned since 88. No electronics at all and problems are easy to diagnose and fix and the very reason why I've taken good care of it right from day 1. Previous to that I had a purchased-new 85 EFI Ranger that was nothing but electrical unreliability and grief right from the start.
                            • #29
                              So Sick your saying when you cranked it you had NO spark at the plug,and that's why you re moving on to look for fuel pressure? Just trying to clarify Boss.....
                              • #30
                                If you jump the fuel pump tester you can hear the fuel in the rail. That's enough pressure to make it run.
