I'm trying to replace the front crank seal on my aqua car.
It has an Aspire engine in it.
The high nose crank is a different setup from what I'm used to and I'm stuck on the removal. There appears to be a large plate covering the timing belt that ie part of the sprocket. (I'm not talking about the big pulley spacer)
I've already removed the sprocket bolt but I can't the sprocket to come off. It wiggles a bit but will jot budge fromthe crank.
How do I get the timing belt off and how do I get the sprocket off?
I'm on mobile right now and can't figure out how to upload a picture.
