My 1990 Ford Festiva is leaking oil and I can see it all over the top left side of my engine and on the underside of my hood in that area.
The car has very high milage, 342,000 miles. The engine has about 60,000 miles less milage on it.
I've looked around the valve cover gasket and I can't see any oil leaking out of it while my engine is running. I also don't see any oil dripping on the ground while engine is running and parked. BUT, I fill the oil up and drive to work and back and then it's time to add oil, I can just about hear my valves clicking. Right after I drive it home from work (about 37 miles), I'll look under it and I can see oil dripping on the ground from different areas under the engine.
I also want to mention that I notice the plastic timing belt cover gasket is coming out from being worn and soft. Is oil being squirted into that area, inside the timing belt cover?
Bottom line is, I don't know where to start. Should I start by putting in a new valve cover gasket? Take off my timing belt cover and get a new gasket for it? Do a compression check to see if the engine has had its day? One last note. The car still does seem to have plenty of power, I can get it up to 75 + mph pretty fast. BUT on certain days it does loose power going up hills, it'll slow down to 55 mph with me giving it all I got. Other days it'll go up the same hill at 65mph.
Any comments or help would be greatly appreciated. I don't feel right about putting all that oil into it every time I go out with it plus I think it may be a fire hazard if all kinds of oil is coming out.
Here's a picture of the top left side of my engine:
