Re: Oil Leak: Still trying to find it...
Yes you probably have excess crank pressure which makes oil leaks worse. First sign is dipstick popping up, so if it's really bad that means you will have low compression and will be losing a lot of power. You will want to rebuild or swap, but remember swap still gives you another used motor, so just depends on what you want to get out of it. If you rebuild you now have a brand new motor vs another motor to deal with leaks and low compression unless you find a low milage one... The aspire one with 50,000 sounds good at least it's fairly low mileage
Sent from my LG-LS970 using Tapatalk 2
