Stripped rear lugs. Upgrade time!
  • Stripped rear lugs. Upgrade time!
    Hey guys.
    The lugnuts on our festiva didn't torque last time we put the wheels on (I suspect they are stripped).
    Looking to replace the rear hubs, hopefully with something better/stronger.
    The other issue we have, is that the set of wheels on the car now are lug-centric. AKA the lugs take all the shear force from the wheel, and I'm concerned this may lead to failure.
    Since we plan to AutoX in the near future, it'd be nice to either get a set of hubs that properly fit the wheels, or a set of adapter plates.
    Suggestions?
    1993 Ford Festiva "Superleggera" 5-Speed
    McMaster Engineering Custom Vehicle Team
    Aside from aftermarket studs (which is what I did) I dont know but I would like to know of other options too
    -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
    -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
      I suppose you could take an M12x1.5 die to them if you really wanted to, but the threads could be weaker or compromised overall. Are you wanting to re-tap the hubs also? That's an option too I guess. I also did aftermarket studs with lug nuts... forged, economical, and high quality. They make wheel swapping 100 times easier for sure. Total cost under $50 including some thread-locker.
      http://www.fordfestiva.com/forums/sh...-with-Loc-tite!)
      1988 Chevy Sprint Turbo 997cc
        Another guy with studs here too! STUDS FTW !! So much easier than the lug bolt things lol
        -M3NTAL MARK! Woo!!
          run a tap thru them, use loc-tite on some studs and run those in up to the collars. Problem solved.
          1989 Carby L: Stock. Slow.
          1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
          2016 Focus ST: daily driven go-kart
            Orrr....if the holes are stripped beyond useable, you could buy press in studs (like most vehicles have).
            Find the proper size drill bit, drill out the lug bolt holes, and install the press in studs.
            This WILL require the removal of the drum to install the studs from the back, in case you didn't know.
            Hope this helps.
              We have a budget to replace all of the suspension, and are looking to put disk brakes on the front so a complete change up (instead of repair) to the back could also be done. Not sure where aftermarket parts can be found for a festiva though.
                Re: Stripped rear lugs. Upgrade time!
                Seems to me that the easiest solution would be to replace the brake drums. That's what the lug bolts screw into... there is no separate hub.
                Sent from somewhere west of here via Tapatalk!
                Ian
                  He just wants to hear do an aspire swap
                  06 Jeep Cherokee Overland
                  95 Aspire (sold)
                    Still need wheel studs with Aspire rear.
                    Anyone know the leingth needed?
                    M1.5x65?
                    HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
                    "CL4P-TP" - 93 Festiva L
                      They are m12x1.5. I believe that studs I installed on mine are 2" long. It also depends on the type lugnuts you use. My 90 has open lug nuts and my 93 uses closed lugnuts. Open meaning that the stud sticks out through the lugnut.
                      Jerry
                      Team Lightning
                      Owner of Team Lightning
                      93 L Lightning. BP
                        Mine are 45mm. 2" would be 50.8mm.
                          I found Aaron's how-to post. Ordered up the ones he suggested a bit ago.
                            I might as well just get press-in studs as everyone has suggested.
                            Want to share this info here? About to order a set of studs, and want to confirm the size/length.
                              Look at post # 7. If I find the length, I'll post it. I think they're 1.5 inch. I know mine work with the long, closed acorn lug nuts.
                              '92 Geo Metro XFi
                              '87 Suzuki Samurai
                              '85 F150, modded 300cid
