having a problem with my radio
  • having a problem with my radio
    It seens that whenever i turn my car off or the radio off and then turn it back on, it resets my presets for some reason. I cant seem to figure it out, any help would be greatly appreciated.
    Sent from my LS670 using Tapatalk 2
    I have a problem with my radio..my hearing is almost gone!
    Check that your battery and ignition power wires are still working
    properly and hooked up right.
      Everytime I hit a bump mine turns off and on. Sometimes I have to smack it again to get it back on. Sometimes it won't turn back on and I have to turn the ignition off and on to get it back on. I think it gives the car character and its hilarious for all my passengers. v.v
      Daily Driver:
      91 Red Ford Festiva L 5spd Stock
      Show Car:
      2004 Black Premium Mustang GT Convertible
        LOL...Ford was the first manufacturer to make the "wiggle jiggle" test part of the flow chart test procedure. Whacking, tapping, kicking, pounding, twisting..tink-a-tink all are professional test procedures!!
        Kick the gas tank and see if it starts...ha
          you may have your two hot wires backwards one is constant for memory and the other is to turn radio on when you turn the key over
            Spray everthing with WD-40 and blow dry.
              X2
              '93 Green L - ' Tiva
                Re: having a problem with my radio
                the radio was fine though i havent though, i havent touched it since owning my car.
