Hello, i have a 89 festiva efi auto trans 80,000 original miles that was running and suddenly died on me, It cranks and sound like it wants to start but just wont. I sprayed starter fluid sounds like it wants to start even more so than without but still does not. So far i check to see if fuel pump is working by disconnecting fuel line hose and starting the car and gas came out letting me know pump is working. Next i took i took some reading on coil and got 9.52 ohms on the secondary and 1 ohm on the primary don't know if thats good or bad ? I am still waiting on my in line spark plug tester to come in. i changed spark plugs and wires. i reset that the switch in the back next to speaker. I disconnected vaf connector and plugged it back still nothing can someone help please i don't want to go changing parts just because. What should i do next.?
Thanks
Thanks
