OK, it's been about 4 years since I changed my sparkplugs and sparkplug wires. Seems to be running fine but way overdue.
What kind of sparkplugs do most of you use?
I used the search engine here and didn't see any overall clear recommendation. If I don't hear anything here, I'll go to my Ford dealer and get some Motorcraft plugs that were specific for the Festiva. I seem to remember somebody here posting that their Festy ran better using plugs that were specific to our cars. I checked 2 days ago and, surprisingly, Motorcraft plugs were only about $3 apiece.
Sparkplug wires: preferences?
If the rotor is clean/no corrosion does it need to be replaced? (Most likely will change it due to the age (changed same time as sparkplugs) since they're not expensive.)
If the distributor cap isn't cracked and the contacts are clean, would you guys change it?
And.....just how long do OEM distributors and coils last? I've owned my Festiva 24 years and I don't think I've had to change them out. Thoughts?
